vividdezigns
Hi everyone, i just came across a Seiki tech 1350T. It was rather cheap so i purchased it. It came witrh Flexi starter, i know entry level but it works. The problem i am having is when i cut smaller letters lets say 5 inches wide by .75 tall it tend to be a difference in were the cutter starts to cut a letter and were it ends, almost like the bl;ade falls into the material before it is perfectly to its start point? can anyone help. I ahve played with knife offset, overcut, it does the same weather it is a arial font that is spelled directly out from flexi, or the same word that is importwed from corel, or signlab or ai that has been converted to cutpaths? I also tried using signblazer b/c it was free to see if i had the same issures. I do not see the isue almost at all with larger detailed objects?? can anyone help????
Thank you
Josh. P/S my second post here..
Thank you
