Setting for an SP-300 just for cutting without printing
Jim Hill
This is something I have never used my SP-300 for in the past.
Customer simply wants white number cut out with no line other then the Magenta cut line. I will then apply transfer paper.
I have tried a few different settings with no luck so far.
Would appreciate all help.
Jim
You first select your contour cut swatch and apply that as an outline to the things needing to be cut. Make your box close to the total size of things being cut.
Take it all over to Versaworks as normal, but just select 'Print Only' in the printer control section.
Go from there and watch it cut.
attachment.php
Jim Hill
My SP-300 uses ColorRip software.
Should it work the same as VersaWorks software.
I have all of the white letters outlined with the cut line color Magenta just not sure what setting to use simply to preform the cutting part.
Do I need to hit print and cut or simply cut?
Thanks Jim
