Should floor vinyl be varnished?
ljwhyte
Just printed my first floor vinyl on a Latex printer using
Textured Direct Print R10 Floor Vinyl 150mic​
My question is, do I now need to protect it somehow ie varnish? Tia
MarkSnelling
Mark Snelling - Hasco Graphics
Can you elaborate a bit? As in putting a wax finish over the floor graphic? If that's the case, I've seen that done so the entire floor has the same surface, but I never understood why people did that because when the graphic is removed there is a spot which needs to be waxed again. I'd also be afraid of the legal implications of not having a UL rated non-slip surface.
Mike Paul
Super Active Member
I wouldn’t put anything over it it if your using the proper material and laminate.
I see a lot of them in stores but I always wondered about the slip and fall lawsuits.
No thanks,
Supermarket blames you not the spilt milk.
