Question Signlab to Summa D75
ATD Signs
Can you cut direct from Signlab to Summa cutter without having to install or use the Winplot
software? Do you need to add any cut lines to the text or graphics?
d fleming
I would think you should be able to once right driver is loaded. And no, you don't need to add anything to text but graphic will need to be vector.
timgo
Graphics Designer
Everything you need is SignLab Print and Cut . Try the Trial Version .
This Program support drivers of your cutter and printer.
ATD Signs
Appreciate your response. I didn't think I needed anything further than Signlab. I am looking into the Signlab 10 version.
Thanks a bunch!
