signs365 GL 207-CL
visual800
we ordered these and they wont stick to anything. I contacted signs365 and they said they have had no issies with others complaining....have you guys had issues with these
Rmurray321
We use this same material with no issue on eco solvent. Only thing I can see that may have an issue is it it’s 100% ink coverage and printed with UV
Does it not work on front or backside? Or only on one side?
Grizzly
It’s all about your print!
These will most likely only cling on the side that does not have ink since they probably print with UV ink.
I would assume that's why they go through all the questions when you order of which side of the window it will be clinging to as well as which side it will be viewed from.
Especially since its the clear version and they have to put white ink down it's definitely not clinging with white ink.
