Small Printers....
Red-Eye
What would you recommend for a small printer?
I have no need for anything larger then a 30" Roland Versacamm.
But I was wondering what other options are out there for something that size.
And what about a separate printer and cutter option?
I only do Decals.
And I say separate cutter/printer because I do alot of heat seal vinyl too, so I'd want the two machines to I can continue easier with the tshirt vinyl while i'm pritning decals.
Thanks.
Custom_Grafx
Second hand sp300v and a gx300 cutter.
If you can afford/fit it, sp540v and gx500.
I'm sure there are mimaki equivalents.
longlivemedia
I recommend the sp540v that Grafx mentioned. It tends to be a bit more pricey, but the results are worth it in my opinion.
CS-SignSupply-TT
Roland 30" versacamm!!!!!
I only do Decals.
Thanks.
Red-Eye, I encourage you to contact Bob Martz-owner, Chesapeake Graphics, http://www.chesapeakegraphics.com/Westminster, MD/ 800.469.3303/410.871.1770/FAX: 410.871.1772 :thumb:
briankb
How does the material and consumable costs of Gerber stack (Edge + Plotter) vs a more traditional Eco-Solvent stack (Roland,Mimaki,ect...)?
I also looked at the Gerber and Summa thermo printers. The 30" Summa looks really nice but the the consumables cost is much higher and resolution is lower than inkjet.
I saw the new Roland BN-20 at ISA and it looks nice but for a little more you can get the 30" SP.
jfiscus
Rap Master
The materials are basically the same as far as vinyls go; for each linear ft you add around $1 per color imprint. So, it's significantly higher than our solvent Epson for full-color prints; but single color prints it's close enough costs-wise. The real benefit is that you can print a 100% solid fill of a specific color (or gradient) onto the material (or specialty material) and the accuracy of the associated cuts is awesome - Especially for small decals and transfers.
