Snowboard deck
JgS
Any recommendations for a vinyl and lamination for the top of a snowboard deck? Needs to go edge to edge. For a park rider.
JoeBoomer
Control Tac
3M Control Tac (180c) w/ 8518,8519, or 8520 should work. I would avoid putting a stomp pad down. If you do want to put a stomp pad down (not that anyone is judging you for using one) ; I would stick that to the actual deck first and trim around it. You don't want the pad pulling on the vinyl.
tiredcreations
yeah, ditto on the training pad
JoeBoomer
No stomp pad on this board. I thought you could only buy those in Texas.
Well played sir, well played.... :) Spoken like a true local.
I guess when you have 'step-ins' you don't need a stomp pad. :)
Seriously though, - If regular 180c Control Tac has any problems due to the bending of the board, I would use IJ-380 Control tac.
Typestries
I have quite a few wrapped decks out on the hill with 50+ days on them. In my experience trimming with a new blade following the sidecut angle helps-blade from the base pointing up. And of course the lift corral topsheet scratches will beat the wrap up but tough to avoid. To this end we tried a floor lam and it made a flexible park board quite stiff. Happy shredding we cant wait fro the flakes to fly.
