Morph1
Print all
Can someone recommend good deal on the head caps, I ordered a set from ebay and they were a complete garbage knock off that would not seal the heads correctly,
spent 4 hours of my time troubleshooting why there was no ink coming from the heads... till I put the old caps back on and got the ink charging back up...
also a question regarding any calibration in regards to the capping station ... is there any sort of adjustment that I can make after swapping the caps to add more pressure to the capping station when it goes into resting position capping the heads, there is a rod with the thread that drives the capping station up capping the heads, can that be adjusted to get a better seal or there is not such thing...
any help would be appreciated.
thanks !
thanks !
