Greeting everyone!
I recently purchased a SP300V. Noticed a slight banding in the black, so I performed a test print. Here it is:
http://farhadevelopment.com/testprint2.jpg
I started off by doing a couple of powerful cleans. Then I did a manual clean, including dabbing the nozzles carefully with Roland cleaner. And I filled the cap with the same cleaner and let it soak. I probably should have clamped the hose to make sure cleaning fluid stayed in the cap, but didn't. Then I ran one more powerful cleaning and did another test print and only showed maybe a 1 or 2% improvement.
I contacted my Roland dealer and he said he should come out and replace the head. Before I go to that expense, should I try other fixes? Perhaps clean out or replace black damper? Change the head cable? My ink cartridge is almost empty, but I pulled it out and shook it and it still feels like it has a bit of ink left.. consistent with what the printer shows.
Does this look like a wasted print head or some other issue?
Thank you, in advance, for offering up advice!
