bruce brown
Hi Folks, I'm new here so I hope someone can help.We have a really urgent problem -we have 2 roland sp540v printers.During a large print, the black ink dropped out halfway through, so we switched to the other printer.Then halfway through the Cyan dropped out on this machine.We called an engineer out and he checked everything and reckoned the heads were faulty.
BUT.... I swapped all the heads around between the 2 printers, and all the heads work in each machine on the red/yellow side but not on blue/black.
I have changed all the manifolds,dampers, caps and tubes.Swapped over the head cables, flushed the heads and tubes, and checked the internal fuses.
The new black/blue dampers are not filling up on one of the printers, not sure why?
There is definitely nothing wrong with the heads, but I am stumped now as to what is wrong, has anyone any any advice?We have no printers and have work backing up, we re desperate to get this fixed.
