SP540-V Temperature too low error
Modtour4
Hope someone can help out.
Before the error: the B/C was printing perfectly but the M/Y wasn't printing at all. Found out the M/Y fuse kept blowing everytime I turned on the subpower. I sent the main board out and had the problem fixed. Once I got it back, I installed it and hooked everything back up. Again, only B/C was printing. Switched the B/C head with the M/Y head and it printed. I then switched the cables and started getting the "Temperature too low" error.
I then put the B/C head back in and still got the error message.
I then installed a new B/C head and a new M/Y head. I replaced all 4 cables with new cables and still get the error message.
Any ideas what to check/do next? I have a fairly large print job coming up and need to get this back running.
Thanks in advance for any help
Russ
Usually when a head fuse blows, it's a short in the head cables but since those are new it's could be damage to the terminals either on the head or the slider board. Head temperature too low means either the room is too cold or the head is not connected properly so it's not getting a reading from the head thermistor.
Modtour4
Thanks for the quick reply.
The temperature of the room is warm. Just did a heater check through the service menu and was able to bring up the temperature to where it was warm to the touch on both the print and dryer heater. I also changed the Print Carriage Board that the cables connect to. Changed the head ranks of both the new boards.
Thanks again
Thanks again
The temperature it's referring to is in the print head not the platen heaters. It tells the printer if the environment is suitable for printing. If it says it's too hot, it's usually a short in the head circuit. If it says it's too cold, it's usually a bad connection in the head. I would double check all the cables to make sure they are plugged in perfectly. If everything looks good, there might be some electrical damage somewhere causing the issue but that is hard to pinpoint unfortunately. I'm not a Roland expert though. Maybe Jim Hancock or Joe House has an idea.
Jim Hancock
Old School Technician
How did you switch the cables? Did you switch them like the attached diagram or did you switch the cables on the one head, i.e., move the left cable to the right side of the head and vice versa? The attached diagram is the only acceptable way to switch cables. You don't want to swap cables on the same head. The 2 cables on a single head carry different data, signals, voltages, etc., so never swap on a single head, only from head to head as shown in the attached pic. Otherwise, you can cause damage to the mainboard.
Modtour4
I'll be honest with you...I really don't remember. I think the second time I tried printing, I left the cables connected to the Print board but switched the cables on the heads. Is there a way to check anything on the mainboard or do I just have to get a new one?
Thanks for your help
Russ
Jim Hancock
The fuses and output transistors can be checked with a multimeter. However, blown fuses and shorted transistors don't typically give you this error. If the ribbons were crisscrossed on the same head, it likely damaged other circuitry on the mainboard, which would be difficult to diagnose and repair. Where are you located?
Modtour4
Jim,
I am located in Mystic CT.
Looks like I need a new mainboard! $$$$$$$$
Russ
Jim Hancock
Unfortunately, it's kind of looking that way. If you did crisscross the ribbons on the K/C head itself, then you most likely blew the head temp sensing circuit, in addition to who knows what. As an example, the schematics show contact 13 on the connector one side of the head being the head temp, but contact 13 on the other connector being ground, and contact 21 on one side being supply voltage and contact 21 on the other connector being ground. Hopefully it did not damage the print heads themselves, but that is a possibility, which I know you do not want to hear. You can get a new board from China for $1300-1400, but it will most likely be an empty board, meaning no firmware, etc, so it would need to be programmed. Roland has 2 in stock, which most likely have the firmware, but I would need to verify that. However they are around $1700, but you know what you are getting. And if it was my machine, I would replace both heads to be sure one of the heads isn't damaged and could possibly damage the replacement main board. You could also send it to whoever repaired it before, if they can go further then repairing the output transistors. Based on your original post, I suspect your m/y head was toast to begin with, as it most likely blew the fuse and maybe a transistor on the channel group to begin with and again when you got it back. Did the repair people tell you what they fixed? That would be useful to me to know to guide you any further.
  • Agree
Reactions: 1 user
Modtour4
Hi Jim,
I was afraid of that, so I ordered a new board. How would I go about installing the firmware? The people that repaired it told me "It wasn't a major short - so we would not expect the head to cause the damage to the board". I do know they soldered in two fuse holders so I have a way to replace the fuse if it blew again instead of having to solder in a new one. The problem happened before I put in the new heads or new cables, so I'm hoping that won't be a problem.
Again, if you could give me any help with installing the firmware when the new board comes in, I'd really appreciate it.
Thanks for all the help/advice
Russ
Jim Hancock
Sure, I can help you. You will need a crossover network cable. Let me know when you expect to receive the board, as I will be out of town next week.
Modtour4
Thanks Jim,
It doesn't look like the board will be here til next week. I ordered a crossover cable, is there anything else I will need?
I really appreciate your help
Russ
Helvyn Santiago
Hi ..Any update for this problem.. i have same problem here. Hurricane Fiona causes a lot of problems to machines in Puerto Rico. Mine have the Temperature too low message.. New Printhead . Printhead cables, flat ribbons.. Change all the cables... also test with another servo...Carriage Board and another main board ..all with the same result... TEMPERATURE TOO LOW ....excuse my english.
Ultraman
Ultraman
Hi! Firstly check cables all connected nicely, did you mess with the print head lately or your room temperature too cold and any ink or cleaning solution touches any print head board(green board)...check all these first. Go to service mode and activate/enable the heater and let it warm up 10 minutes then restart again.
  • Agree
Reactions: 1 user
Kakaye
J'ai aussi le problème et j'ai suivi vos conseils apportés à halvin Santiago. Mais je ne sais pas comment faire pour augmenter la température. Merci pour votre intervention
Kakaye
Salut! Tout d'abord, vérifiez que les câbles sont bien connectés, avez-vous dérangé la tête d'impression récemment ou la température de votre pièce est-elle trop froide et toute encre ou solution de nettoyage touche-t-elle n'importe quelle carte de tête d'impression (carte verte)... vérifiez tout cela en premier. Passez en mode service et activez/activez le chauffage et laissez-le chauffer 10 minutes, puis redémarrez à nouveau.
J'ai aussi le problème et j'ai suivi vos conseils apportés à halvin Santiago. Mais je ne sais pas comment faire pour augmenter la température, quelqu'un peut m'orienter s'il vous plaît. Merci pour votre intervention
