Have had this issue several times earlier this week. Running some moderately long wrap prints, about 45 min on fast quality. Job gets about 3/4 of the way done and then printer beeps and the print head stops halfway across the platen. Display just shows "PROCESSING." Job drops off of VersaWorks like its completed. I have to shut the main power off and back on in order to revive it.
I sent the service log to tech, he said the last couple of errors were 0002. He also said the scan motor has 3000 hours on it. He want's to replace the scan motor first to see if that fixes it. However, in my research, 0002 is a communications error between main and servo boards. I don't want to jus start throwing parts at an issue. Also, it may be worth mentioning, I was running some banners before these errors started showing up, and had a pretty bad jam as the head hit a big wrinkle in the material. Anybody have suggestions on how to figure out exactly what the issue is?
