heyskull
Last week I had an issue of some of one part of the black and part of the cyan went blocked and wasnt printing correctly.
I worked out that the pump wasn't pulling through, so I removed the complete station and cleaned the pump and fitted a new cap.
This seemed to cure the issue, until I came in on Saturday and the left hand black line into the head was empty of ink.
So I cleaned it again and found that the new cap was not quiet sitting right in the station, so I reset it as it was been held centrally with the lower spring.
This morning I ran a test print and due to how well I keep this machine clean the test print was perfect.
But on printing a print with a lot of black coverage this afternoon I am getting black spots as if the head is dripping.
The dampers have never been replaced on this machine as I was told by the last tech that replaced the head that "hew would only change dampers on a solvent machine if it had an issue"!
Does this sound like a damper issue as it does to me?
Cheers
SC
Cheers
SC
