White Haus
Not a Newbie
We print a lot of customer-supplied files that contain spot white fills. We mostly use Spot1 (Onyx) but occasionally we use RDG_WHITE (Versaworks/Roland).
There are times where the supplied files are set up with the wrong spot color. Depending on workload or lead time for the project, we will sometimes fix the file (in illustrator or corel, or replace colors in onyx) or send it back to the customer, but either way it results in a delay or extra pre-press work.
Is there a way to replace a spot color within Acrobat Pro? I've found a few areas within the Print Production tab that identifies the spot colors and separations, but have yet to come across the option to replace it. I'm also curious if there is a way to simply rename the spot color and if that would work.
For example, we would need to replace RDG_WHITE with Spot1 or vice-versa.
Thanks.
Thanks.
