Suchi C3 Question on file converting?
Mosumart Design
Dear All..Hi this is my first thread since I'm new here.
I bought a China Brand Plotter called SUCHI C3..everything works on par except the file to output to the cutter has a bit complex to do..
It uses PLT format and saved to the Flash drive provided by Suchi then plug to the cutter to cut.
I am wondering is there any workaround or tips on converting from pdf to plt at the easiest way? (As I have Summa D60R can use pdf as cutting file through winplot).
I read that plt is HPGL file format and must go through HP equipments /tool before it can be used as cutting file format.
Any ideas guys?
