summa d140...is there a pause button?
gabagoo
Only had the cutter for 8 years.... So if I am cutting a job and need to make adjustments to the blade how does one pause the cutter? Just put a new blade in and run this cutter exclusively from Flexi for cutting printed matter...In fact the software that runs it will only cut printed matter so even doing test cuts is tough
Bly
Press the menu button.
It should pause at the end of the current cut.
Then hit the exit button once.
