Summa f1612 electrical question
Coleholley
Hey! I have a summa f1612 and recently moved locations. It was wired for 208 3 phase before but new location doesn’t have 3 phase. From the research I’ve done on here I’m planning on using an ADX15 3 phase converter, is that enough hp?
And then also little confused, will I need a transformer too? If so what exactly?
cornholio
Hi, go to the Summa website and look for the site preparation PDF.
I never installed a F on single phase here in Europe, but I know it's possible.
The only 3 phase part is the vacuum pump motor. In the single phase version, it's a single phase motor with capacitor.
Maybe it's cheaper to replace the pump.
ProColorGraphics
I went digital with mine. I talked to a machine shop who has used every type and HIGHLY recommended spending the extra on a digital one. Just make sure you get the surge protector. That wasn't an option when I got mine, but added one on both the standard side and the 3ph side.
This is what I got:
ProColorGraphics
I did add a transformer after the converter as well. I have 240v coming in, so that makes the 3ph 240v. The Summa is setup for 208v. After the techs came, I was told that they could rewire it to handle 240v.
I am pretty sure this is the transformer I got:
netsol
This is what I got:
i think i would gree with whoever said the vacuum pump is the only part that requires 3 phase power
that may be ONE BIG VACUUM PUMP, however
