Need Help Summa/Onyx skips vertical cutpaths
Carroji
Hi!
I have a problem with a cutfile. I'm printing on an Epson s80600 using the ONYX Rip and then cutting with Summa. I can see all the cut-paths (both vertical & horizontal + circles) in Onyx and it doesn't seem to be anything odd. The vertical and horizontal path are flex paths and the circles are kiss-cut.
When Summa is cutting it skips all the vertical paths completely. I've had this happen to another job before and I can't seem to figure out whats causing it. I used the same pdf to cut with Winplot and it doesn't have the same problem. I make all cut-paths the same way and it seems to be happening randomly (not often though).
Has anyone had the same problem or know whats causing it?
