I am a little confused on how the Summa barcode works.  Could someone clarify?
I have a Oce Colorado (Onyx Thrive) used to print and Summa cutter with OPOS.
As I understand the barcode server needs to run on a compatible RIP. Can this run on my Onyx Thrive 321? I have 2 printers already connected to my Thrive RIP so I am guessing that I need to get another RIP for the Summa? Is it possible to run the barcode cutting from a PC connected to the Summa using Caldera and use my Colorado running Onyx Thrive to print the design with barcode?
What would be the best most economical solution to get the barcode cutting to work?
TIA!
TIA!
