Jumpshoutmedia
Ugg. Like a dummy, I was moving the dampers around and I heard the sound you never want to hear (CRACK), and the damper on my BRAND NEW black DX4 printhead went loose.
I quickly found out that I had snapped the plastic nipple off inside the damper!
So in a panic, I grabbed one of the old printheads and removed the plastic adapter plate from it.
I cleaned it up, and flushed some cleaner fluid through each of nipples, and the cleaner sprayed out nice and clear out of each side, so I assumed that it was fine, and I installed it onto the newly damaged head (which printed PERFECTLY up to that point).
When I reinstalled the head and ran a test print, I immediately noticed that the entire pattern looked messed up, almost like the head was physically damaged really badly (but I know it was wasn't). All did was swap a broken adapter with a non-broken, used one.
(Photo attached)
I'm assuming that what happened was the old adapter was partially clogged, or had some coagulated ink inside of it, and that debris made its way into the head when I tried to put some ink through it.
It's been an entire day, and I've run a dozen of medium cleanings and it's still not getting any better.
Have I FUBAR'd a brand new head? Or is there something I can do to restore it? Or is this something that can be fixed by one of those cleaning/restoration services?
Any advise would be greatly appreciated!
Thanks.
(Photo attached)
Thanks.
