Click to Support Signs101 ...
Greetings! I have a Yellotools back-slitting knife, which is great. But bringing in blades from the US to here in Canada is a pain - I was wondering if they are proprietory or is there an equivalent out there? Anyone recognize them?
These aren't the same as safety razor blades, these are much thicker and work much better in the type of cutter he's using (I've used safety razor blades in a pinch when I'm out of my normal ones).
Martor blades are what I use, specifically these ones although there are thicker or thinner blades available.
We have a distributor in Canada www.signmakertools.ca if that helps. I can also ship out to you from the USA but there will be a customs charge. Hope this helps.
check the prices carefully. I've made two orders in the pass and it was cheaper to order from the US site and pay for the custom than order from the canadian distributor.
But if you want to order the blades from a canadian seller, try this one
