this plotter
Geneva Olson
Expert Storyteller
ok. i am 100% sure this is user error. But I am wracking my brain trying to figure this one out.
We are plotting on material that is 48" wide. I plot a box that is 45" wide and it will not cut the left side at all. WHAT am i doing wrong?
amw
Longtime Members
I may be mistaken, however i think there is an option in the settings (on the plotter) called over cut or something like that. It will then cut past where the wheels start.
Not sure if that will help you, I have a migraine.
Good luck and Happy Friday!
Geneva Olson
Expert Storyteller
ok. i pulled the pinch rollers out futher and set the origin point after I loaded the material. it's working now. But I did make sure that there was over 45"
between the pinch rollers.
it works.
JBurton
Signtologist
Make sure if you have a weed border added that you include that in the space between the pinch rollers. So for 45" wide, plus a 1/2" weed border, you'll need at least 46" between the pinch rollers.
