signmancanada
We have a Toucan LT, and are having feed issues. This problem has been on-going for some time now, yet had a very pronounced example of it the other day. The issue is inconsistant feed rate. Grrrrr!!
We've seen examples where we pull a panel out of the rip archive and reprint and the panel is a different size than original. We have seen multiple panels that are different lengths than others. The other day.....
Printed two small signs side by side. About 10 inches into the print, banding gradually started over about two inches. Then full banding. Did not have the presence of mind to check the feed rate to see if it has changed, but others having the same problem say that it's not the case, that the feed rate stays the same throughout. Over 36" in length the print was a full 1/2" shorter than it should have been. This all makes sense, if somehow, the feed rate changed.
The next morning I asked the fellas to reprint. They pulled from the archive and reprinted. It was perfect. No banding and full size!!!!!
Any ideas?
Any ideas?
