transfering onyx from my pc that died
the graphics co
My main computer that ran onyx recently died. It has a hardware error and i cannot get to the windows screen.
Is there any way to salvage my copy of onyx off of it? It is thrive 19.
any help is appreciated.
victor bogdanov
Take out the hard drive (if its not the harddrive that failed) and install in your new computer, or get whatever the problem is with your computer fixed. Every single component in your PC is replaceable. You'll only lose data if it is the hardrive that failed and you do not have a backup
  • Agree
Reactions: 1 user
What victor said. There are ways of recovering data from broken hard drives but I'd simply plug it into a new computer and see what happens first. Also, does Onyx have a way to transfer the license to new computer? Whenever I run into this issue with Rasterlink, we just deregister the license and reregister on the new computer. That is, if you still have your license code.
the graphics co
I have a keyed usb for the license, so I imagine it should work on a new system. Thanks for the help.
netsol
if you don't have installation media & product key for rasterlink, contact tech support.
they can certainly give you the product key
YOU COULD ALSO purchase a hard drive dock for about $40 but i am not sure how to read product key when the drive is installed as a slave (D: drive)
did you consider having someone look at the computer? there are very few things that are complicated to fix if you know your way around a pc
fire it up long enough to display the product key , copy the install file (if it was a download) and reinstall...
netsol
any half way competent tech can at least transfer hard drive to another computer in safe mode, long enough to retrieve product key, enabling a re-install
