transparent layer with thin white edge!
rumskinz
hi everyone im new here, i have a problem with importing psd image layers from photoshop to flexisign pro 8.1, the cut out layers have been feathered using photoshop tool and looks spot on, but when imported to flexi on closeup you can see white outline as if flexi does not support the feather tool, ive noticed the thicker the feather to transparent the thicker it shows white in flexi, any help would be great!
thewood
I've never had luck with Flexi supporting transparencies. It even has issues with proprietary transparent effects created within Flexi.
eahicks
Flexi 10.5.1 handles PSDs wonderfully, with transparencies. Also lets you apply contour cut and when you do so, it acts as a mask as well. Very handy.
LittleSnakey
Flexi 10.5 pdf does not handle transparencies any differently than in 8.1 you will get the same white behind any part of the transparent graphics ie shadow or a gradient that goes from color to transparent.
If you need a color other than white for a background draw it in photo shop on a separate layer,
in photoshop export it without the background,
import into flexi,
add countour cut
separate contour cut
release contour cut you will use this path to mask later
Now back to photoshop
export with background as jpg (file is smaller than psd)
Import into flexi,
align with original transparent both centers
move released contour cut path to front
use that to mask jpg
delete transparent jpg.
This may work for you.
FrankW
The Flexi 10.5.1-Successor FlexiCloud (Flexi 11) should handle transparency layers out of Adobe Software (shure with PDF, it is a key feature, not shure with Photoshop). Flexi 10.5.1 not.
