trying to get head tilt pattern
jiro
hi all,
trying to get a head tilt pattern , looking in the mutoh maintenance manual in the self diagnosis chapter.when going to the adjust black tilt, hit enter prompts to set paper. but when i put vinyl in printer and put the handle down the printer rolls it out.
RG
Hello, jiro. Are you putting in a sheet of vinyl or a roll of vinyl? If it's a roll, make sure that the printer is set up for roll feed. Sounds like you may have accidentally hit the button on the control panel and set it for sheet feed. Good luck.
