UCJV feed correction and dot position adjustment
willkho
I saw that the ujv100 is equipped with a DAS (Dot Adjustment System) function as standard, which automatically adjusts the dot position correction and media feed amount.
Does it mean with UCJV300 you need to do feed correction and adjust drop position every time you change media?
APCInk
Yes, the UCJV has no automatic scanning system. You should check the Drop Position adjust when changing thickness of materials or the head height and check the feed comp when you change rolls.
