Need Help UCJV300-160 Stops cutting mid job when another job is queued after
RonnyCrack
I am able to run a full print and cut job no problem, but if I try multiple executions, or multiple different jobs queued up, it will stop mid cut on the first job, before starting the second row of sheets. It switches to local and clears the data for the rest of the cut job. If I were to switch back to remote it would start the next print job on top of the second row of the last job.
If I just let them fully end, and then start a new job, no issues. It also doesn't seem to cause an issue if I queue up the second job while the first job is already most of the way through the cut portion.
