UCJV300 overprint on 1 layer
willkho
Hi all,
if not mistaken, ucjv can do multiple overprints on one layer only? I can't find a way to do it.
For instance:
I want to build up texture using clear then cmyk on top.
To reach the heigh I desired, I need 5 overprint of clear but just 1 overprint CMYK (5 over print cmyk will be too dark).
Is it possible?
Smoke_Jaguar
Best bet for building up clear is a CMYK/Clear gloss on pass 1, then pull-back and do a second gloss. Will get some nice thick prints, at least in my experience. Using Rasterlink 7 here, so not sure if using aftermarket RIPs.
Goatshaver
Shaving goats and eating bushes
If you want to do raised under the 4 color. Best way would be to make a White ink layer and a Build layer (100% of CMYK) for what you want raised up. Regular ink and white are thicker than the clear and will build up faster.
I'm not totally familiar with the 300 but you should be able to do 5 layers (BUILD>WHITE>BUILD>WHITE>CMYK)
willkho
yupe, I always use pullback, but sometimes it doesn't work with the alignment, occasionally head strike.
willkho
interesting, I've never tried 5 layers for this, will surely try it.
The build is the clear ink right?
Goatshaver
