UCJV300 - Third Party Inks
akawa
Hi,
Looking at potentially changing over to third party inks on my UCJV300.
Has anyone done this and would be able to share their experience in terms of the quality after the change. Did you need to do a flush when changing over?
Smoke_Jaguar
Looking at a UJV100-160 and was looking into inks for it, and yeah, seems the LUS-170 and LUS-200 inks are pretty much non-existent in the aftermarket.
As for changing inks, always a good idea to flush where possible. As long as the ink is compatible with the printhead (Gen5 IIRC), you should be good from a technical standpoint. As for accuracy and printing profiles, you might have to do some color checking and make some new ones for the new ink.
Bordeaux has an aftermarket ink for the LUS170s. I don't have any customers using it yet but I'm pretty sure it's because most people are still under warranty so they haven't made the switch yet.
Smoke_Jaguar
Looks interesting, but also f**k companies that won't list their prices on their site. It's a bottle of ink, not a house in Beverly Hills.
Bordeaux sells through dealers so that's probably why they don't have the price on there but I agree, giving people an idea about the cost would be helpful!
Smoke_Jaguar
Only vendor I found is $97. Based on the SDS it seems like decent stuff. Claims Gen3/4 compatibility as well on the sheet, so Gen5 is almost a given.
White Haus
Not a Newbie
Interesting. Would be curious who is using it and how it's been performing.
I wonder if they also sell a cleaning solution that doesn't only come in shot glass size bottles...........getting sick of buying the Mimaki F-200/LF200 CLEANING LIQUID in 100 ml bottles....pretty ridiculous.
Smoke_Jaguar
Isopropanol is nice for head and panel wipe-downs as it isn't aggressive on the plastics.
SGC
Huh? STS & JetBest are both available and easy to find in the US on first page of google. Both work great.
SGC
Hi,
I’ve used both STS & JetBest 170 compatible. Both are no flush from OEM. If you don’t like the one, swap an OEM in, and try the next one when that bottles over. I experienced no print differences with either.
Smoke_Jaguar
Only tested Bordeaux and Mimaki so far, Bordeaux MK170 was $99/liter last time I got it from ieion , looks like LexJet stocks Marabu for $117.12/liter. I get Mimaki LUS-170 for $143.50. Not much savings there, but maybe if the ink had some distinct advantages. My experience with UV inks is most are pretty similar with some variance in color. Not averse to trying it, but only marginal savings. That, and I am a cheap mofo who buys inks without chips and can get it for under $80/liter.
Horton Signs
I know this is a slightly older thread, but has anyone had any luck with the inks mentioned, Bordeaux, Jetbest. I'm quite intrigued to find out what others experience has been like. We're based in New Zealand and genuine Mimaki LUS170 costs around $370 NZD per litre and have been able to find Jetbest inks for around $170-200 NZD.
I can see from the Bordeaux website that these don't require flushing the lines, does anyone know whether the same is true of Jetbest. I couldn't find anything specifically.
I'm trying to find direct replacements for LUS170 and LUS150 for our UCJV300-160 and JFX200-2513EX
