using a mat cutter to cut coro sintra?
signwizz
has anyone tried to use a logan or c&h mat cutter to cut coro or sintra or plexi ? just wondering if they would work or not rigid enough to handle thicker material?
Are you talking about an actual matte cutter ?? If so, yes. You might need multiple scores.
Pat Whatley
3mm Coro - no problem
10mm Coro - several passes plus changing the blade depth
2mm Sintra - couple of passes
,060 Styrene - score and snap
Acrylic - Turn the blade over so that the square edge, not the sharp edge, is on the plastic. Score several times and snap
