Geneva Olson
Expert Storyteller
So. can anyone tell me the good, the bad, and the ugly of a UV printer?
TIA
TIA
I see there are now choices of rigid or flexible inksGood: Cures virtually immediately, prints white better than other ink types, multi layer printing for cool effects, no heaters, ink is cheaper, can print direct to substrates, low to no solvent content.
Bad: Laminating may require a heat assist laminator or liquid lam, clogged nozzles are harder to recover, inks cure hard which makes doing non-flat installs more difficult without cracking but they get better every year it seems.
Ugly: They cost a lot more than other options. Heads and maintenance parts are more expensive.
To add: No need for transfer tape or time to assemble vinyl, most sign panels are done once printer is done. They can be fast and add ability to your shop. We make multi layer glass signs - like the glass on pinball machines - print directly onto wood, canvas frames, magnetic, PET banner material for rollup displays.So. can anyone tell me the good, the bad, and the ugly of a UV printer?
TIA
They can be a bit loud. All substrate must lay perfectly flat in order to print - uneven surfaces come out fuzzy, head crashes can be expensive... They have a large footprint and specific electrical needs (no 120v...). If you do daily maintenance you have few problems, however you will need to adjust vacuum pressure for the heads a couple of times per year, print white daily, and perform a variety of maintenance like filter changes and greasing rails.
If you get a plotter with crop mark detection, like a Graphtec or Summa, you can then print on the flatbed and cut. Print quality is very high on the new machines - our FluidColor flatbed has high resolution than our Roland XR-640. You can also order cutouts, print a jig on the table, and direct print the graphics.
Last issue: while you will need the right electrical installed before the machine arrives, you will also need a way to get the machine off the truck, out of the crate and into your building - we have used a flatbed tow truck for this. But make sure you have a entry that is large enough that equipment can get to...
The Issues I spoke of are not for one single brand. We have had a CET before the FluidColor. Both are based off the HandTop framework. There are many others that start with a HandTop frame as well.I think these issues are specifically for your fluidcolor brand flatbed...
- The vacuum table pulls down the substrate to lay flat. mask it up properly and it's good.
- Adjust vacuum pressure for heads??? 8 years and i've never done this, nor have i heard of anyone do this.
- while head crashes are a thing, most flatbeds have a good detection system preventing those.
Airflow is key, but I still don't like to stand next to the flatbed. I get it running then leave the area.Everyone is talking about a smell but on both of our EFI printers I smell very little. I have more smell that comes off our ecosolvent printer than 2 large format EFI UV printers. Guess it comes down to how much air flow your building has.
We had a defective UV machine out of the box a while back where the head carriage was up too high and wouldn't allow us to lower it. It still printed fine but due to the improper height, it coated the entire inside of the machine in yellow ink dust. Makes me wonder how much ink dust it makes that we just don't see.Airflow is key, but I still don't like to stand next to the flatbed. I get it running then leave the area.
We have a garage with a ramp..so i would think that would work. But, what are the dimensions of the machine?To add: No need for transfer tape or time to assemble vinyl, most sign panels are done once printer is done. They can be fast and add ability to your shop. We make multi layer glass signs - like the glass on pinball machines - print directly onto wood, canvas frames, magnetic, PET banner material for rollup displays.
196"wide X 78"Long X 56" high. In your workspace you will need another 2' all the way around the machine minimum. This is for one that prints to 4'x8'We have a garage with a ramp..so i would think that would work. But, what are the dimensions of the machine?
They work great. You can even print a layered print that will look different when lit and unlit.I was curious how well the UV roll to roll printers work. Forgive my ignorance, but are they capable of printing backlit graphics?
Yes, we print backlits with our UV flat bed (also has roll to roll)I was curious how well the UV roll to roll printers work. Forgive my ignorance, but are they capable of printing backlit graphics?
Well depends what brand...I was curious how well the UV roll to roll printers work. Forgive my ignorance, but are they capable of printing backlit graphics?
