Vacuum Tanker
rjssigns
Hi guys and gals,
My client has a tank truck used for drain cleaning and he wants their logo on the tank. Truck gets pressure washed everyday no way around it. I was thinking about using an aggressive vinyl like DPF8000, or similar, then edge sealing. Or would cast with cast lam work if edge sealed? Masking and painting is out of the budget.
Largest piece will be 40" x 40".
graphics guru
use convex hibond or convex cold weather vinyl with lamenate...i have used it on cinder block walls and a wall at a tennis court...but we alos make alot of decals that go on logging equipment with same product...tough stuff...washing everyday is tricky no matter what cause then you run into ..what product are the using to wash with,,,what pressure stream is being applied...yadda yadd
