whiteknucklegraphx
I have just set up our equipment ValueJet 1204, Ultima cutter and flexi print DX. I can print great, cut great, but contour cutting is killing me. I can contour cut fine out of flexi using the mutoh registration mark. The problem is using one of the marks with the bar codes. I have installed the cut server software and have had a couple of files work but it is hit and miss. If the cut file goes to the cut server and has a number at the end of the file name it works, if it doesn't have that number then I cant cut it. Can someone please tell me what registration marks to use in both the cut server and flexi.
thank You!
thank You!
