I agree with above. If you're in high head height on thin vinyl it can cause fuzziness. Also, the bidirectional alignment will also affect the print like that if it's off. Go into Menu>Setup>User Type>Print Adjust. There's a rough and fine pattern. Do the rough first and then the fine. It will print out some patterns and you just input into the printer which one lines up the best.
