VE Lxi production manager issue
Brever
For some reason when I send my job to production manager from my VE LXi software it is cutting a square around the image and or font. It has never done this before and I can’t seem to figure out why. It’s not always a perfect square either, it depends on the type of font I use. I’m not adding an outline or contour to the job either. Could someone please help me with this issue? I would greatly appreciate it. Thanks so much in advance, Brever
mfatty500
Sounds like you have the"easy weed" option checked in PM. At the top of the cut/plot window, right under properties there are 4 selection to choose from, select options, and you will see Weed Lines, and you'll see the options available
Brever
Thank you for the information. I’ll check this evening when I get home. I tried to look on PM for a setting that may cause it but didn’t see any but I’ll check that for sure.
Thanks again
Brever
OMG! That is what it was. It has never done that before so I must have hit that option by accident. Thank you so much for the info! I really appreciate it!
