Vectorizing an image
greysquirrel
I have vector magic...works 60% of the time...when in doubt use vectorize now...cheap and quick turnaround
  • Agree
Reactions: 1 user
Inkscape works incredibly well and it's free. It's certainly good enough for any project I've ever had to use it for and as a screen printing shop we've done a TON of logo vector conversions over the years. We even took a low res photo of an MMA fighter once and converted it to a 128 color vector that allowed us to blow it up onto a 6' x 6' banner and the vector looked far better than what resampling the low-quality raster image could have ever produced, in my opinion.
  • Agree
Reactions: 2 users
Ricsy84
Where can i download the full soft?Better than VectorMagic 1.15?
WildWestDesigns
You can export your files as eps or svg.
Inkscape's native format is SVG actually. There is a "plain" SVG and really that is more geared to web work as it cuts down the extra XML data (open up an SVG in a text editor and can see that XML markup) that makes it easier to us CSS and JS with SVGs. Once 1.0 is stable, quite a bit more abilities with different SVGs versions (even have an optimized one), html5 canvas version as well.
EPS is quite finicky with Inkscape. I would suggest keeping it as SVG, just may have to use Plain instead of the default. But that does depend on what machine you are sending it to needs. Some can't parse out that extra info on it's own and some can.
However, both of those options will be found in the "Save As" dialogue box. The only file format that Inkscape technically "exports" is PNG.
