versa works roland sp540
Mark Roberts
Wow...that's a long time. I think there is a problem somewhere. How much RAM are you running? What about available disk space?
Depends on your dpi you designed at and what quality setting. For a 4x8 sign the SP 540 takes about 1 hour at standard quality. You may check the time with your Versaworks as to how long it will take to print. The XC540 would take 30 minutes for your job to print.
baasman73
Just export it as 150 dpi Tiff or JPG (little or no compression)
and run it on generic banner high speed mode with pass
just done 60feet in under 3 hr
