Need Help VersaCAMM SP-300v Ink Problem
Facundo38541
graphic designer
Hi, I'm the owner of a VersaCAMM SP-300v printer. A few day ago I was trying to change the language of the printer and I think I changed the ink mode by mistake and now it shows me a error message and I can't connect it with Versaworks.
This is the error message
G-Tech
Go to your applications and in the Roland VersaWorks folder choose Initialize Application (you will loose any work in Versoworks). It should reconnect to your printer with the correct set of inks. Roland MAX inks only CMYK !
