versacamm sp300
crewchief97
I have a Versacamm sp 300 and was just wondering how long it can sit without printing anything. If it's slow I run a test print every other day is this ok or can I go longer? Thanks for all replies
Sign Works
If it's gonna sit idle for any extended period of time insure that the cap tops are in good condition or else you may experience head dry-up. My SP-300V has sat idle for several weeks on several occasions without causing any problems.
S
scarface
Guest
I have my SP300i which is just a newer model to do a automatic cleaning twice a day. That way if it is sitting it's still getting used in some way.
crewchief97
Thanks Sign Works for the quick reply. I've had my Versacamm almost a week and learning so much. Thanks again!!
Mosh
As long as it is plugged in it should pull ink every 8 hours or so. You should hear the pump going.
crewchief97
So if it goes into sleep mode it will cycle ink on its own every eight hrs. Then I don't need to do any test prints or anything?
Thanks guys you are great help to a newbie!!
S
scarface
Guest
That should be right, that's what I've been doing but seems that i'm getting busier so the printer doesn't sit as long anymore.
