Versaworks Banner Feed Calibration Settings
player
I noticed the generic banner profiles use 0 feed calibration, while the SPVCB PVC Banner profile uses 1.35 feed calibration.
I have found the best profile for banner is when I use the Oracal 3651 vinyl profile, but I did a 16' banner and it was 1 inch short in length.
The heaters are also 35 and 40, while the 3651 is 40 and 40.
I am copying the 3651 and changing it to be my banner profile, and I am wondering if anyone could shed some light on that 1.35 feed calibration setting, as in what does it do?
I am printing with a VP540i.
Run the feed calibration on the printer and set Versaworks to let the printer handle the feed compensation rather than the profile. I never understood why they put the feed calibration in Versaworks profiles. Everyone's is going to be a little different so having it set in a profile is kind of useless. There should be a setting to allow the printer rather than the profile handle the calibration in Versaworks.
Your printer should be able to print a 16' banner with a distance accuracy of +/- .576". So at 1 inch you are out of spec which means that either the feed calibration is way off or something else is wrong.
Ragnabrok
All the versaworks generic profiles have feed calibration set to 0, since generic isn't an actual media. Vander is right to print the feed calibration test on the printer (menu->calibration->test print) and input the setting that looks most like a continuous line, no gap or overlap. From there in the job settings, under printer controls you can set it to "use printer settings". It takes less than a minute and uses a little over a linear inch of media.
player
Thanks guys. That is exactly what I did. Worked perfectly. ( I have not measured it though).
