VersaWorks Preferences "Preview-Quality" ??
splizaat
I've always passed over this option since I never really saw a difference when I changed the options, but maybe someone here can give me a rundown. In VersaWorks under the General Tab there's a section titled "Preview" with options for Quality and a check box to enable monitor proofing.
I've set the quality to high quality and enabled monitor proofing (although not sure which Monitor Profile to use??) and I see absolutely no difference in versaworks.
Can someone explain to me what this option does and what the proper settings are? I'm finally curious enough to ask :)
If you are profiling your display using a device (colorimeter or spectrophotometer), you would point VW to the current monitor profile. In the job settings dialog the on-screen color will be more accurate to the printed output (if this functionality is enabled).
