VG540 Cutting problems. The printer heads are not staying in the capping area
Using VW dual to do the job
The printer will print out the job and then go back into the capping station
Then the cutter and the heads will come out to cut the job. It causing a motor error to happen during the job
Has this happen to anyone?
I'm not sure how the new models are handling this but most other Roland printers would fix this by running the limit position initialization in the service menu.
-Fusion
Have you had any issues with alignment? I can't get mine to stay aligned for more than 12" of media....
And I haven't had this happen to me. I have had 6 motor errors and when I called the Techs they said this has been an issue with these.
I do but I think its more of a VW dual problem than a printer problem.
Let's say i have a small decal 5x5 that I need 200 of. If I upload a single version of it to VWdual and then repeat its... the cut line is almost always off for 85% of the decals.
NOW if I sent it to VWdual as one large file with all copies in one file. Never a problem
__________________
Hey houseofgrafix,
VanderJ (above) is correct, the limit initialize will likely help, but only Roland authorized dealers have the procedure to perform that correction. Please contact your Roland dealer ASAP to discuss getting this issue resolved. They may have to go onsite to handle this for you (and possibly tune up the printer. e.g. wire/belt tension adjustments, etc).
If you want to continue the conversation with Roland directly, it's recommended that you complete our support submission form so we can create a support ticket for you. Go here to submit your info: Product Support Form | Roland
We look forward to helping you and take care,
Roland Technical Support
Roland DGA Corp.
rn
