Joesignshop
Hello- I recently had Lt. Magenta ink dropout on large sections of the test print. This happened before and I changed the damper and worked perfectly. Now it started again 4 months later, so I changed the damper out and now test print is perfect and printing well.
Two things: the dampers are from Digiprint and aftermarket and it seems that the pouch on one side (lt magenta) is filling up only halfway which is odd. The other side of the same damper (lt cyan) is filling all the way to top. Is this normal to have the top portion not filled but still works fine? Maybe the problem lies elsewhere in that line? Is there a way to manually fill that side of the damper with the tubes coming off the top?
**I know, I know should've bought Roland dampers.
