dweinmann
A local fitness center wants to have their name and the weight amount applied to ends of 40 sets of dumbbells. These end pieces are a painted metal with some sort of protective finish. On the end pieces, there are two recesses, the top will have "UGL" and the smaller one will have the weight amount "5".
We are using a cast 3M vinyl and want to put a protective layer over it to protect it from weightroom debris, sweat, etc. On our first try, we used a bottle of clear polyurethane that did not ever turn clear. It stayed a milky white color. On our second attempt, we dropped some Frog Juice into the recesses and evenly coated the recess. After about 20 minutes, the vinyl would curl around the edges around the "UGL" and the weight "5" formed a few creases (I'm guessing the frog juices seeped under it somehow).
Any suggestions on what to use here? Again, we're just looking to coat the recess to protect the vinyl from peeling up. Also, any ideas on what caused the frog juice to curl and crease the vinyl? Thanks in advance for your assistance.
