Hello,
I've decided to hobby sign to see if its anything I am good at and should pursue. My question is I was considering the corner of my bedroom for workspace and storage.
Are there smells or major fumes associated with vinyl?
Do I need a rack to store the vinyl or is leaving it in the box (where they are all sorta stacked on each other) ok?
If I need a rack, is vertical the best?
Should I leave the plastic on it when not in use to keep it clean?
I had considered briefly garage, however I live in Pahrump (hour out of Las Vegas) and the heat in the garage in the summer is over powering. Dust no matter how often I dust is also an issue so I will have a sheet over the cutter when not in use.
Thanks for everyones previous posts as well, I have been doing a lot of searching and learning.
Hint for other new posters, instead of using the title to tell us you are new poster, PLEASE put the general idea of the question in the title, makes it loads easier when people are browsing the determine which might be the most informative or information that they need.
Thanks again!
Jolie
Thanks again!
Jolie
