Hi there!
I'm looking into using wrap vinyl to cover items for exhibition stands (counter tops, walls, etc. – see my earlier post!).
I've got a sample of some printable white wrap vinyl, which I'm about to have a test with on a circular 'coffee table' top, which is 600mm diameter.
What I'd like to know, before I get 'wrapped up' in doing it (see what I did there?!), is what do I do with the underside of the material.
I reckon I should cut about an 800mm diameter circle, and lay over the top, which should be no problem, and using heat I should be able to stretch the vinyl around the 1" thick edges, but what do I do with the reverse side bits? Should I cut slits in the vinyl once fitted to the top and sided, almost to the edge, then overlap these on the underside one by one? (Hope that makes sense...)
Anyway, anyone with any experience of doing this - maybe even on vehicular parts - I really welcome your help!
Thanks!
Thanks!
