Vinyl Wrapping a concave wall questions.
zcreative
So I've been being sent on some large vinyl installs for my work, covering entire restaurants interiors in a concrete/marble printed texture.
Generally I've just been tacking the panels under the ceiling and applying downward (the panels are about 52x96). It's been going well however I have a job coming up where there is a small dining area that has concave rounded walls. Probably about 5 of those panels total.
Obviously tacking to the ceiling won't work because of the curve. Just wondering if anyone has any suggestions on how I should apply these?
Forty One
Make signs they said... It'll be fun they said...
We use a high tack vinyl when we do our wall prints.
And because of that, we spray the walls down with a litte soapy water.
Just enough to make sure the prin doesn't bite immediately and we can reposition as needed.
This worked a treat when I had to apply it to a curved wall.
ddarlak
Go Bills!
I recently did a concave wall and was worried about going top down, I ended up trying top down and it worked fine. I used the 6mil vinyl from kapco that has a canvas texture to it. It worked beautifully. Just squeegee center out, center out and you'll be fine.
