Gurupreet Dhanjal
Hi Guys, i have a huge problem, My VJ1204 is not printing at all, nothing is coming out of the head, i have read thru all the posts here and basically, the dampers are fine and the capping station is also sucking properly.
I did the suggested trick of sucking from the pipes under the capping station using a syringe and the ink is flowing out.
To go back to where the problem started i had removed the head to clean the head assembly as after printing several hundred meters of banner there was a lot of fuzz stuck around the head and the assembly which was not coming out with normal cleaning and my prints had streaks in them.
When i returned the head i started getting a Head heat error, after going thru the forums i decided to make sure the ribbon cables were placed properly after which the error stopped. But now although everything seems fine the head is not firing at all.
Having gone thru the forums i have the following theories,
Either the Head Fuses are gone in which case i need to know where they are located and how to test them to see if they are functioning,
Or the Mainboard has a problem in which case i am screwed!!!!
Any help you guys may be able to offer will be highly appreciated, also i urgently need the Service manual for this Machine.
