I have a couple of things going on with my VJ 1204. For some reason, even though I have it cleaning itself every 18 hours, somehow I still ended up with damn near an entire missing bank of cyan one morning. I've soaked the heads via pad soaked with cleaning solution in the capping station for about thirty minutes, but only got back a few bars when I did the nozzle check (after a strong cleaning). Went to do a second strong cleaning and BAM - out of magenta. <sigh> Now I can't put the printer to sleep, it won't let me, I'm guessing until I replace the magenta. Can't get another magenta cart here until probably Monday at the earliest. Do I turn the printer off? Leave it on? Park the head on a soaked pad again until then? I DO have a cleaning cart, should I replace the empty magenta with that?
I pulled the capping station and checked the drain lines and they seem to be draining fine; I can see stuff moving into the clear tubes when doing the cleaning.
Should the cleaning fluid STAY in the capping station? Meaning, if I fill it up, is it supposed to stay full? Or is it supposed to drain? Mine drains; you can see the fluid sit there for a few but after a second or two you can see the top of the pad as the fluid gets lower and lower. Is that right? I'd think that would mean there's a leak somewhere as isn't the cap / capping station supposed to be airtight?
Not sure what I should do next really, so here's a corn dog.
Edit: While typing this out and editing, my printer shut down the vacuum but still won't go to sleep.
Appreciate any thoughts,
S.
S.
